dividedhighw »
https://forums.nicoclub.com/dividedhighw-u95262.html
Sun Apr 26, 2009 2:10 am
A taller tire will give better ride comfort, but lesser handling. Other than these two aspects, you've already hit on the 2 other main things to consider when using a different tire size, accuracy of electronically-imputed speed (e.g. speedometer, VDC, etc) and mechanical fitment (e.g. wheel rub if the tire/wheel combo is too high or too wide). If none of these is a practical issue for you, then go ahead and save some money.
As you correctly pointed out, with a higher profile tire speed will be off, in your example +1.1 mph, from factory wheels/tires, but be sure you understand that means the speedometer will read slower than your actual speed.
Although I've never bought anything from them, I've heard tirerack "knows their stuff", so you might want to pose that question directly to them.
Cheers,David
