I researched some tire sizes online for a few days and finally purchased a size that I was almost positive would fit: 235/50/18. My car is a 2005 Altima SER with Tein S.Tech lowering springs in the front (2" drop), stock height in the rear.
The dimensions of the stock SER rim are 18 x 8, and the stock tire size is 225/45/18 (what I have installed now). After searching around I found posts on other forums of people saying that their "stock 7.5" rim came with 225's from the factory" and "235's would definitely fit an 8" rim". In the rear I have a little more than 2 fingers worth of wheel gap and at least 3 up front, so I figured 50-series tires would fit, seeing that the stock is 45-series...
But after visiting the local Monroe Muffler and Brake shop they refused to install the tires. They thought that I would definitely rub and that I might even need spacers up front. They didn't install them and held the tire up my car on the lift and said they didn't think it would fit.
Does anyone know if these tires will fit? Am I incorrect in making the assumptions that I did? I used this wheel size calculator to see how far off the new tires would be from stock and the new tires are only 0.6" wider and 0.6" taller than the stock ones... http://www.powerdog.com/tiresize.cgi Is my fender well really that tight of a fit that I can't even fit tires 1 size up from stock?
EDIT: 12/23/10
According to PowerDog's calculator here's the comparison between the stock tires for the SER (top row) compared to the tires I installed (bottom row):
Here's some pictures of the final product. The tires fit and I've only rubbed when I've had 3 people in my car (including myself) and hit medium sized bumps, like if I pull into a gas station or plaza too quickly. The rubbing is in the rear, on the very outside of the tire right where the tread slopes down to meet the sidewall, so the tires still tuck even with the bigger dimensions.
Back of the rear tires to show width, about 0.4" wider than stock
About 1 finger worth of "wheel gap" in the rear
Rear again
Front of rear
Back of rear
