235-50-18 on 2008 G37 base???
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
hgevgili
Car: 2008 G37
I am about to buy 4 used snow tires for my 2008 G37 (originals 225-50-18) for $250. They are going to be a bit bigger, will they cause any problem. Please help and advice. Thanks.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
use the tire size calculator on www.1010tires.com. Key in oem size compare it to new size, if +/- 3% in diameter, you should reconsider the size.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
