23 or 24 inch rims on Titan?
Covering the 2003-2015 first-gen and 2016+ Titan and Titan XD lineup
reveille_83
hey folks. was wondering if anyone has had luck or knows someone who has put 23 or 24 inch rims on a Titan. I have seen a few trucks with 22s on cardomain but nothing bigger then that. i am curious because i'm looking to do it myself.
if you have put those on did you have to change anything? other then getting low pro tires i assume
thanks in advance.
jdmfreak
I would stick with the 22s. 23/24s are pushin it. Are you planning on getting spinners or just regular chromes.
reveille_83
i was thinking of getting 23 inch Rozzi Vixens.
can be found at http://www.rozziwheels.com
jdmfreak
Which ones?
jdmfreak
Oh and how much?
SmithSR
Car: 240sx
No reason you couldn't. Only real restriction is making absolutely certain that the tire you choose has equal to or greater than OEM load index.
Toyo knows people are putting 24, 26, and now 28" wheels on the H2, and there has been serious errors because for some time there was not a properly plus-sized tire that met the load requirement of the H2 in the larger than 23" sizes. Because of this, Toyo is one brand that will not (at least yet) enter the fray and build tires that are so close to, if not below, the load requirements. There's only so much a tire company can do, when budget restrictions for such a limited market come into play.
This was months ago, and looking around the industry today, with 28's about to be delivered to the doorstep of retailers everywhere, Kumho is releasing tires that carry a proper load rating for the most extreme of applications. An example is their 28" tire retailing at $1k per.
Just double check that load rating!!
Which Titan trim level did you get with what size tire?
jdmfreak
$1K a piece? DAMN!!!
kc4x4
Car: nissan frontier
thats the stupidest idea i've ever herd its a truck treat it like on intead of haveing all chromed out rims spend it on something good like a 3 or 6 inch lift and some 35 inch tires
Return to “Nissan Titan Forum”
