Yellow4g63 wrote:Damn that sucker runs rich to go -14%
Hey, did you get the Walbro fuel pump?
You probably have WAY too much fuel pressure, that is why its running so rich.
The Walbro pump overruns the stock fuel pressure regulator, meaning that the regualtor cannot allow enough fuel to flow through to consistantly maintain 43PSI....the last car I checked was 51-56 at idle with the vacuum off.
This Walbro upgrade is what is making all the cars run so rich.
I highly recommend that everyone double check their fuel pressure and reset it with an adjustable fuel pressure regulator.
