DTASFAB »
https://forums.nicoclub.com/dtasfab-u223076.html
Wed Sep 10, 2014 8:23 am
Many tire manufacturers will not warranty their tires if installed on a vehicle that calls for a higher speed rating, so be aware of that.
As for dropping from V to H on a 2011 Rogue, I wouldn't see much problem with it from a safety risk standpoint. Mostly what happens when you go to a lower speed rated tire, the walls of the tire are softer (and sometimes the rubber on the tread is harder, making for slightly worse traction but better longevity) making the ride squishier with worse handling.
But with 18" wheels and only a 55 profile, I wouldn't worry about squishiness, not when the 16" wheels on the base model came with 70 profile tires. If anything, you might want to make your ride a little softer, and I don't think your handling would be affected in the slightest in this case. I think the 225/60/17 tires that came on the SV hit the perfect sweet spot for the Rogue.
