20x8.5 ET 35 rims fit my 06 M45?
gibz4
I found a great deal on some TSW rims that are 20 x 8.5 with an offset of 35. Will these work with my 06 M45? I know the stock offset is 45 but will the diff by 10 have problems? By the way i'm not lowered yet but thinking of dropping it using Tien H springs. I've seen a response from Mexillis but i was wondering if anyone else had issues.
Thanks,
Gil
rgb129
Car: 2008 550i sport
RIP 2006 M35x
gibz4 wrote:I found a great deal on some TSW rims that are 20 x 8.5 with an offset of 35. Will these work with my 06 M45? I know the stock offset is 45 but will the diff by 10 have problems? By the way i'm not lowered yet but thinking of dropping it using Tien H springs. I've seen a response from Mexillis but i was wondering if anyone else had issues.
Thanks,
Gil
Yes, they will. I just put new wheels on tonight that are 20x8.5 +35mm. They look perfect. Flush with the fender. I will post pics from the Import Alliance show tomorrow. My car is going in as one of Precision Motoring's cars. Unfortunately, my car will be "cheapened" by sitting next to the Bentley they have done. I do have my car lowered on coilovers with the fender an inch above the wheel.
rgb129
RIP 2006 M35x
Here is what I put on tonight...looks absolutely clean on a black M.
blfolson
Car: 06 M 35x
pics please
skim35
Car: Infiniti M37 Sport
Here is my M but its lowered with JC COilovers( for sale by the way)
My wheel specs are below here are pics 9x20 and 10x20 offsets are +35 and I have a 10mm spacer in the front and a 5mm spacer in the rear so your 8.5 will fit no problem especially if its not lowered.
http://www.cardomain.com/ride/3161021
rgb129
RIP 2006 M35x
Here are mine with 20x8.5 +35mm. Nice and flush with the fenders.
InfinM3506
Car: 06 Infiniti M35 Luxury Edition, Journey Package, Tech Package, Burnt Orange Leather. Eibach Pro Springs, 20" Vossen CV3 20x9 255/30/20. 20X10.5 285/25/20. 08 Front Infiniti Sport Changeout.
*Skim35* When putting the 5mm wheel spacer on your car did you need to make any changes to your bolt sizes? I just put a set of Vossen CV3 Silver 20X9 +38 - 255/30/20 on the Front and 20x10.5 +45 - 285/25/20 on the Rear. Rear's are Perfect just a lil over flush but perfect fit with it being lowered on Eibachs. The fronts I wanna make them flush or same as the rears. So wondering if i can just put in the 5mm wheel spacer without changing the bolt out or if i would need the longer bolt for the lug nuts to grab? Please let me know very interested.
Thanks.
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
You will be fine with a 5mm spacer. No need to change anything.
anotheraznguy
Car: 2005 Nissan 350z
1989 Nissan 240sx
2006 Infiniti M35
skim35 wrote:Here is my M but its lowered with JC COilovers( for sale by the way)
are the offsets before or after spacer?
InfinM3506
DoN_BLaZe34 wrote:You will be fine with a 5mm spacer. No need to change anything.
If i go 7 or 8mm would that be too big. Where i would need to change out the bolts? and would 5mm do much really? I want to give my front wheels more of a flush look. Rears are out just a lil.
mexillis
Car: M45s
You might be able to do 10 with out changing to longer studs. You should be able to fit a 15 mm spacer with your specs and some of those come with studs and hub rings built in.
mexillis
Car: M45s
http://www.autornd.com/product-p/ic-sws-subaru.htmthis will help you find out exactly what will fit
DoN_BLaZe34
2006 FX45 - Traded
5mm wouldn't drastically change anything. You may be able to get away with 7 or 8...I personally would look towards changing the studs at or above 10mm...of course u could always get spacers would the longer studs already in them
ISman
Car: 2006 M45 Sport
rgb129 wrote:Here are mine with 20x8.5 +35mm. Nice and flush with the fenders.
What exhaust do you have on your car? looks fantastic.
Partysan7
Car: 2008 M35
I have that same exhaust f/s its magnaflow 14816 or at least thats what it looks like
