20x10 owners
New2Import
Car: 06 M45
What offset did you guys run in the rear? I got a 20x10 with a 40MM offset and I did a test fit and looks like Im gonna have to send this back again. They are sticky out past the fender. Im gonna get a tire one tomorrow and do another test fit before I go powder coat them. If you have pics please post up.
ATSELLAB
Car: 2006 Infiniti M45
hey those will fit, when you get a tire on it and put it on the ground it ll tuck in. If you had a lower off set youd have a problem
New2Import
Car: 06 M45
You thing so looking at the pics now. I jack up the wheel another jack to compress the spring. Ive never seen it stick out that far.
Front view
Rear view
kkalahiki
Car: M35
New2Import wrote:You thing so looking at the pics now. I jack up the wheel another jack to compress the spring. Ive never seen it stick out that far.
Front view
Rear view
I'm running 20x10 on the rear and it was installed today. The offset is +35. I just had to down size the tires from 275x35 R20 to 265x35 R20. No rubbing at all.
New2Import
Car: 06 M45
Care to post pics? Im going to get a tire put on one today and test fit sitting on ground to see. I just want to make sure before I go get them powdered coated.
kkalahiki
Car: M35
Pics sent to your e-mail address. I still have to re-size the pics to post here.
M4T5
Car: 2007 Infiniti M45
20x10? Wow, those things will make your M follow every road inconsistency! It will look good though.
J
paperfootball
I run a 20x10 with a +40 offset with a 275/30/20 in the rear. I am dropped on on TEINS with no rubbing.
New2Import
Car: 06 M45
Well I dont know how you guys do it unless you got mutipeice wheels. I dont see it happening with cast wheels. Im gonna get something else with a 45MM offset.
szh
Car: 2018 Tesla Model 3.
New2Import wrote:Well I dont know how you guys do it unless you got mutipeice wheels.
They may be relying on the profile of the tire being narrower nearer the tread (away from the hub that is). Plus, the motion of the wheel is not straight up and down - the top of the tire "tips in" when moving up, so it may clear the fender edge.
An alternative is to roll the fender to give the tire some room.
New2Import wrote:I dont see it happening with cast wheels. Im gonna get something else with a 45MM offset.
Ummm ... please be careful and check the fitment (not saying that you should not do it - just check it carefully at a friendly tire dealership who will mount and check wheels)!
With a 10" width, that 45mm offset may contact suspension components since the wheel will sit further "in" than a 40mm offset wheel. But, since I have not tried this myself, all I can say is "check it out carefully", since the stock 2006+ M wheels (which are narrower than 10" wide!) have 47 and 50mm offsets, by the way.
Z
