ShootToKill »
https://forums.nicoclub.com/shoottokill-u76292.html
Sun Sep 16, 2007 7:51 pm
well with every one here comparing the 20b to the ls1. i guess i can throw in my .02, being someone who has owned both an s13 and a rx7. both motors make about the same amount of power. ls1 is around 400hp i believe, and the 20b is around 380hp. weight wise i have no idea what the exact lsx w/ t56 weighs but i'm sure that its enough. now i do know what the 20b with fc/fd trans weighs in around 280lbs, trans is only 60lbs of that. i have owned both an fc and an s13, and both were relatively well modified, hands down the fc will run circles around the s13, in terms of handling, balance, and performance.
now i don't know what you plan on doing with this car. if this is your daily, not such a good idea. the 20b is a very finicky motor, as all rotaries are. and tuning, crazy idea, its a 20b, it makes almost 400hp, leave it stock. its a rotary, so don't think your gas milage is going to be good either. but if you are going for unique and fun, go for it. its something i have been wanting to do with a 13b-re or 13b-rew. the only problems you would run into in this swap, would be the ecu and wiring, which your only real choices would be standalone (megasquirt, microtech, link, etc.) and then finding some one who is really good at tuning rotaries (steve kan), but i don't know where your located.
as for the racing crap, i don't think he plans on running 24 hour leman any time soon. either way you go with this, its your car, do what you want with it. and yea rotaries pop every 10k miles, thats why mine went out at 160k mi.
