VStar650CL wrote: ↑Sat Mar 23, 2024 1:16 pm
ASIST doesn't say explicitly, but I think It should work on Canada models. For a non-Navi the current update is 5188, for a Navi it's 5192. For a Navi, you should be able to hook the car to your home WiFi and do an OTA update yourself.
Thanks again for your help. Thought I'd give an update based on my experience here in Canada.
First time I tried the ""MENU" & toggle it didn't work - I suspect an "operator error" because next time I tried it worked and allowed me to get to the right place.
I'm thinking that the Canadian versions may be different...
My Overall SW Version shows 5352 22 05 2023 which is considerably higher than the 5192 that you mentioned for the Navi model.
I've never used the method which you suggested but it is fantastic in that it gives a treasure trove of information - some of which I admittedly don't understand - this is where i play the "seniors" card - I'll be 80 in November this year.
I have always checked & updated the software thru the touch screen & it now says that I have the latest version of the software.
Just thought I'd share this for what it's worth....
Cheers = Roger from Paradise, Newfoundland & Labrador.
