2022 pathfinder fuse box location
nyzjatt
Car: ???
Hey, I was changing all the interior lights to LED lights however now none of the lights turn on even when I try to use the old bulbs. This is making me thing the fuse was blown. I'm trying to access the passenger fuse box however I have no idea where it is. I'm not able to locate what the diagram in the owner's manual is showing. Any ideas on whats wrong or how to access the fuse box?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I've only worked on one of them so far, but I seem to recall the inside fuses are all above the driver's kick panel. I can take a look in ASIST for you tomorrow.
nyzjatt
Car: ???
Thank you I really appreciate it!! Ill try taking a look again tomorrow as well
VStar650CL
Technical Expert
The fusebox should indeed be on the firewall near the driver's left foot and fuse 24 is for the interior lamps. It should be a 10A in the second slot down at the top of the 3rd column (top slot unoccupied). Wish I could post a pic, but the "attachment" function here seems to be broken and I can't do Google Drive from the shop.
