2022 Nissan Rogue 1.5L turbo BOV Location?
Jacek2282
Car: 2022 Nissan Rogue 1.5L Turbo
Does anyone know where the new 2022 Nissan rogues 1.5L turbo blow off valve is located? I would like to switch it out, to get some little noise going and hear the turbo spool up a bit more then stock.
Doesn't have one, to my knowledge. It is recirculated most likely.
Jacek2282
Has anyone confirmed it? I know the setup is way too new but I’m hoping there is a BOV that can be replaced and a aftermarket one put on
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
No BOV, it has an electric Wastegate and a recirculating Bypass Valve. They work in tandem with the VC system on drop-throttle to eliminate the need for a blowoff.
Jacek2282
VStar650CL wrote:
Tue Mar 29, 2022 11:30 am
got you.. thanks
VStar650CL
Technical Expert
Sorry it isn't what you wanted to hear, but you're most welcome, happy to help.
Jacek2282
VStar650CL wrote:
Tue Mar 29, 2022 1:33 pm
ok sooo, i finally figured out how to put the 2022 rogue in the manual only mode without it switching it back to D mode......and i did a 4th gear pull, when i was under boost, i heard the BOV go off and it was pretty loud, but only stock loud, basically,,,, i think the car has BOV just need to find out where.... can anyone confirm this yet, anyone looked into it? i know its no race car but......
VStar650CL
Technical Expert
I dunno, the FSM doesn't show any blowoff, just a bypass valve. I'd imagine that could get loud when relieving high boost pressure just like a blowoff, but I don't think it can vent to atmosphere like a traditional BOV.
Return to “Rogue Forum”
