I am wondering if the reason for the issue has be found.
VStar650CL wrote: ↑Wed Sep 15, 2021 7:02 pmThere are actually a couple of bulletins about RST on the '20~'21 Sentra.
One is for the lock function. The way the BCM firmware is set up, the doors must be locked already before you press Lock for the RST sequence. So if the car is sitting unlocked, you have to press Lock-Lock-RST instead of just Lock-RST. I'm not sure if there needs to be a delay between the two Locks.
The second bulletin is for a code the ECM (engine controller) may throw if two RST's in a row are attempted too quickly. The code is a P161F, and your RST will stop working until it's cleared. It won't cause a check engine light, so you won't know it's there without scanning. Just erase it and your RST should start working again. Here's the bulletin:
https://static.nhtsa.gov/odi/tsbs/2020/ ... 0-0001.pdf
