2021 rogue tow hitch and wire harness
computerguy
Car: 2005 Nissan 350Z Roadster
2021 Nissan Rogue Platinum AWD
I noticed that also and wondered why they are even going to run the hot wire from the battery when they could have picked it op on the prewire. Once again thanks for all the info by the way is the hot connector on the prewire fuse installed at the factory?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I'm sure it's fused but I didn't notice where. I'll find out and post back.
computerguy
That would be great could save running a wire to the battery
VStar650CL
Technical Expert
computerguy wrote:
Fri May 07, 2021 2:17 pm
Sorry, computerguy, got your PM but you seem to have yours turned off. I had a crazy week and forgot all about it, I'll look tomorrow.
computerguy
OK thanks
computerguy
Check my profile and indeed I had my PM's shut off now they are turned on THANKS!
VStar650CL
Technical Expert
Very cool, the prewire has a dedicated 30A fuse with nothing else on the circuit. Fuse 86 in the Fuse & Relay Box. It's battery and not ignition, so if you use it for anything besides a brake controller, be careful about key-off power draw.
computerguy
Thanks, you are a great resource to this forum, that's no different than the way the trailer guys wire it straight from the battery via a fuse. Getting trailer hitch installed Tuesday will tell installer should save some time on the install.
VStar650CL
Technical Expert
computerguy wrote:
Sat May 15, 2021 12:48 pm
You're most welcome! Heck yes, and a whole lot cleaner and safer than running a live batt+ wire underneath the car!
WestCoastBluenoser
Car: 2021 Nissan Rogue Platinum
VStar650CL wrote:
Sat May 15, 2021 4:44 pm
Hi VStar650CL, thanks for all the info you have posted!
First time poster here - I previously installed a hitch on my 2021 Rogue and am about to buy the Curt 56459 wiring harness my local dealer finally has in stock; I can't find any other options readily available here in Canada.
I'd like to avoid running power from the battery, what is the best way to connect to the prewire you previously showed us? I assume I'll need some sort of connector?
Thanks!
VStar650CL
Technical Expert
You're most welcome. As mentioned above, the prewire for the righthand turn signal also has battery power from a dedicated fuse in the Fuse & Relay Box. That's the definitely the best option.
nvnvnvnvn
Car: 2021 Nissan Rogue SV
VStar650CL wrote:
Wed Jul 14, 2021 12:06 pm
In case there is someone as challenged as I was...
At least on my 2021 Rogue (SV), There is a fuse/relay box under the hood on driver side. There is description under the cover of the fuses. There is one that shows 30 trailer. I used a 10amp fuse because I am not controlling any brakes, just a couple of lights. I got a 10amp fuse from the spare fuse section of the fuses located inside cabin, under the steering wheel. There is a fuse puller located in here as well.
Return to “Rogue Forum”
