VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Mon Mar 02, 2026 3:25 pm
Sorry for the late reply, I just saw your post. If the CVT fluid has never been changed, I suggest doing two consecutive spill-and-fills with about 1K in between to void about 75% of the old fluid. Do the first one simple, change the fluid cold and replace exactly what you take out. It's up to you if you want to get more complicated on the second one. If you feel up to it, you can drop and clean out the pan (there will be a scum of break-in clutch material coating the bottom and very fine metal shavings on the magnets). Unless you find substantial metal stuck to the two magnets (shavings 1mm or larger), just blow the main filter clean (it's a screen and not a real filter) and don't bother with the paper one at all (it's there for break-in and nothing else, Nissan doesn't recommend ever changing it, and changing it is a PITA). You can either do the second spill cold as well (being careful to catch all the spent fluid when you drop the pan so you can refill accurately) or warm it up beforehand and use the leveling plug afterward, but bear in mind that using the plug requires all 4 corners of the car to be raised evenly.
