2020 Rogue Steelies offset
AntonWJ
Car: 2020 Nissan Rogue AWD
Hi to the forum!
I have been trying to find out what is the offset for a 2020 Nissan Rogue steel wheel (17x7). Lots of info on the web that shows either a 50mm, 40mm or 35mm offset, so I don't know which one is correct. Do you guys have any info on this? Is it stamped on the wheel?
Thank you,
Antonio
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
What's your car's trim level?
Trim: S & SV
Size: 17x7.5 (O.E. Diameter)
Offset: +35mm
Trim: SL
Size: 19x8 (O.E. Diameter)
Offset: +45mm
Trim: SL
Size: 19x8.5 (O.E. Diameter)
Offset: +50mm
AntonWJ
Thanks for the quick reply. The trim for my Rogue is "S", I thought that trim was the only one to come with steel rims. Thanks for the info.
Rogue One
2022 Honda Pilot SE
You're welcome.
Sometimes it's best to err on the side of caution. Once at a Nissan dealership where I worked, we had a lady that was trading in her 1st gen Rogue that was badged as an SL, even though it was clearly a base model.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Rogue One wrote:
Tue Mar 23, 2021 3:00 pm
Hm, counterfeit. How roguish!
Return to “Rogue Forum”
