Radio removal is easy. Remove hard plastic between glove box and dash. Next is to pull out the HVAC controls. Third is to remove the panel that holds the push button ignition.randylisadhanraj wrote: ↑Mon Mar 08, 2021 12:49 pmok, thanks. do you know if you have remove the radio as well?
No need to remove the radio to get the cluster out, but Boss is right, the radios are easy-peasy. Just make sure you have a pocket magnet, some of the screws are a PITA to get out with fingers and you don't want to drop them in the dash or console.randylisadhanraj wrote: ↑Mon Mar 08, 2021 12:49 pmok, thanks. do you know if you have remove the radio as well?
