2010 - 2011 Murano with Nav TSB Updated!
Forum for the unique Murano, and official home of Nissan Murano Club!
BillArf
Car: 2011 Murano LE AWD
Note, today 7/15/11 after a trip to the dealership, I did edit/update this post. Please read this edited original post here again as TSB number has been updated along with more listed in the list of issues that this TSB addresses.
TSB NTB10-125b
This TSB addresses:
•Audio streaming via Bluetooth is “choppy” or “clipped.”
• “Calculating Route” takes an extended period of time (2-5 minutes) to complete.
• “Could not find a route” displays when attempting to calculate a route.
• Voice Recognition sequence takes too many steps.
• The Navigation system reboots.
• Voice Recognition has difficulty recognizing voicetags.
• "Handset Phonebook" access is slow
• XM NavTraffic is slow to report
• When hands free call via Bluetooth is in progress and another call comes in there is no function available to answer the incoming call.
When making appt. with dealer for this TSB fix have them check to see if they have the NTB10-125b/ITB10-066b Reprogramming Software DVD that is necessary or they need to order it.
Anyway, I am in Upstate NY and I had a local dealership's Service dept. address TSB NTB10-125b with a date of 4/20/11 mentioned in my first post. After the DVD re-programming of the Nav system in my 2011 Murano LE, I now have Nav Program version X1U62025. Per Nissan after the reprogramming it was necessary that I have either Program version X1U62025 or Program version X2U22025. As I mentioned I ended up with X1U62025.
If you have a 2010/2011 Murano with Nav manufacturered before 5/1/2011 you will want the dealer to complete TSB NTB10-125b with a date of 4/20/11 on your 2010/2011 Murano with Nav unless you already have Nav Program version X1U62025 or Program version X2U22025..
When making appt. with dealer for this TSB fix have them check to see if they have the NTB10-125b/ITB10-066b Reprogramming Software DVD that is necessary or they will need to order it.
I can report I see the fixes addressed in the TSB. The DVD reprogramming did what it was suppose to. Took the dealer about 45 or so minutes to do the reprogramming. I waited for vehicle while they did the work.
Return to “Murano Forum”
