I don't own a rogue, but a sentra, so it's basically starting from 0, or at least somewhat.
this radio is going to my Sentra for 2 reasons, 1) because i retrofitted the Factory Around view (360 cameras) and with the radio 2591A5UD0A the module turns off after 20 secs, with this radio it doesn't, and 2) because this radio has built-in Maps as well as carplay android auto.
With the sentra radio, 2591A5UD0A, you're able to make the lights turn on with ground on pin 9 (20 pin) and positive on pin 58 (40 Pin), however it doesn't seem to do anything with the rogue radios. In the rogue radio i can only see pin 58 as being positive for the lights but doesn't do anything, any help will be appreciated.
