gahollett12 »
https://forums.nicoclub.com/gahollett12-u296692.html
Mon Jul 13, 2020 10:00 am
Bought the current 7 inch screen stereo, part number 2591A5UD0B out of a 2019 Sentra and installed it in my 2018.5 Versa Note( my Note has the 7 inch screen but does not have Carplay or XM radio). The 40 pin plug, 20 pin plug, XM plug and USB plug plugged into the new unit, the AM/FM antenna is the same color gray but does not plug in, needs to be modified/changed. Sentra car details are in the radio menu, the radio powered on but nothing seemed to work, no back up camera with shifted into reverse, no steering wheel controls worked, Bluetooth would not find other Bluetooth devices. Radio on AM and FM would looks for channels but can't test due to the antenna plug. My question, can the radio be placed into an hard reset to remove the Sentra firmware and see it is connected to an Versa? Will an factory reset enable the camera and steering wheel controls? Is the issue that the wiring harnesses different and I need to find the pin outs for each car? Thanks in advance for your assistance
