2019 Nissan Frontier SV and Oneplus 9 Smart Phone (Android 12)
Post all your Nissan electronics, car audio and stereo questions here!
texastig
Car: 2019 Nissan Frontier
I got a new Oneplus 9 phone (Android 12) last Friday but my 2019 Nissan Frontier SV won't connect to it. My older phone a Samsung Galaxy S8 connected fine.
Would anyone have any ideas to help me?
Thanks
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2012 Honda CR-V LX
2022 Honda Pilot Special Edition
Is your phone the Oneplus 9 5G, or the Oneplus 9 Pro 5G?
Which carrier? T-Mobile or someone else?
Setup Guide
To connect your device through Bluetooth, your vehicle must be stationary.
STEP #1: PREPARE YOUR PHONE
TURN BLUETOOTH ON:
On Off
  • From the Main Screen:
  • Select "Settings"
  • Select "Bluetooth"
  • Select the Bluetooth switch to turn it to "On" or "Off"
STEP #2: PREPARE YOUR VEHICLE
To turn Bluetooth on if it's not automatically on:
  • Press the "Menu" button
  • Select "Connections"
  • Select the "Bluetooth" tab (It should be selected by default)
  • Select the gear icon on the right
  • Make sure the light by "On" is lit up, if not, select it
To connect a phone:
  • Select "Add New"
STEP #3: PAIR YOUR PHONE TO THE VEHICLE
ON YOUR PHONE:
  • Add Connection
  1. From the Main Screen:
  2. Select "Settings"
  3. Select "Bluetooth"
  4. Select "Pair new device"
  5. Select "[MY-CAR]"
  6. When prompted by the phone
  7. enter the PIN number displayed on the vehicle
  8. then select "Ok" on the phone"
  • Remove Connection
  4. Select "Settings" icon next to "[MY-CAR]"
  5. Select "Unpair"
STEP #4: ADDING YOUR CONTACTS TO THE VEHICLE
Each paired phone has its own dedicated phonebook.
Two phonebook setup options are available depending on your phone's support for Phonebook Access
  • OPTION 1: PHONES WHICH SUPPORT PHONEBOOK ACCESS:
  1. When a phone is connected to the system, the phonebook is automatically downloaded to the vehicle. No additional setup is required to begin voice-dialing contacts by name.
  • OPTION 2: PHONES WHICH DO NOT SUPPORT PHONEBOOK ACCESS OR WHERE AUTOMATIC PHONEBOOK DOWNLOAD IS TURNED OFF IN THE PHONE & BLUETOOTH SETTINGS MENU:
  1. ON YOUR VEHICLE:
  2. Press the "Menu" button
  3. Select "Settings"
  4. Select "Phone"
  5. Select "Phonebook"
  6. Select "Download Entire Phonebook"
texastig
My phone is Oneplus 9 5G.
My carrier is T-Mobile.
I'll try your instructions.
Thank you.
texastig
Your instructions didn't work. I called the local Nissan dealer and they said to factory reset the bluetooth in the settings. Now my Oneplus 9 works fine.
I do appreciate your post.
