2019 Frontier Air Bag
oldnissanguy
Car: 2023 Nissan Rogue S AWD
2013 Nissan Rogue SE
2004 Mazda B3000 DS
Is it safe to reconnect the battery after disconnecting and removing the side impact air bag switch in the door? I am installing power locks and power windows so I would like to have the power on but don't want to risk any unseemly and expensive air bag explosions.
macgiver
All I can say THAT'S SERIOUS BUSINESS , and ya better get safe & PROPER advice here , and get more than ONE opinion , like if it's easy to hunt down a nice honest dealer body mechanic.
BE SAFE ............and I'm not talki'n about F 'n Covid here :lolling:
p.s. It most especially has danger in disconnect and reconnecting these things - there ARE specific procedures ,OK. :yesnod
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
No, it isn't safe. Remove the fuse for the airbag brain, then you can reconnect the battery and turn the ignition on without worrying about the bags.
macgiver
See .....looks like ALL power MUST be OFF (battery & associated fuses disconnected) when disconnecting OR connecting OR "fiddling" with ANY SRS airbag location !!!!!!!!!!!!!!!!!!!
Right VStar ?
VStar ,would maybe wrist ground strap be a good caution , like the procedures handling delicate Mosfets and circuit boards ??
VStar650CL
Technical Expert
Kill the battery first and always when working with bags. Fuses can spark invisibly, fingertips can spark from static charge, etc, etc, etc, Short cuts can lead to the earth-shattering kaboom.
macgiver
There's that Venusian- like MARTIAN!!!!!!!!! OK , ok... again................NOW I'M SCARED , please don't be 'waiting' for me...... :rotflmao
VStar650CL
Technical Expert
macgiver wrote:
Sat Feb 19, 2022 2:09 pm
Generally speaking, discharging yourself frequently to the body of the car will suffice. Just touch bare metal, such as the door stopper. Static discharge is the main concern.
macgiver
Along the lines of what I figured , thank you sir .
VStar650CL
Technical Expert
macgiver wrote:
Sat Feb 19, 2022 2:17 pm
There's that Venusian again................NOW I'M SCARED , please don't be 'waiting' for me...... :rotflmao
C'mon, you know better than that. Marvin is a Martian. His goofy green guys are Venusians. Get with the program.
:lolling:
macgiver
I just fixed my " goof " , thank you sir .
VStar650CL
Technical Expert
macgiver wrote:
Sat Feb 19, 2022 2:25 pm
:dblthumb:
oldnissanguy
2004 Mazda B3000 DS
Just to be sure I understand:
Disconnect the battery
Remove air bag fuse
Remove air bag sensor in door
Reconnect battery and do whatever I need
Disconnect battery when done
Reinstall air bag sensor
Reinstall air bag fuse
Reconnect battery
This correct?
VStar650CL
Technical Expert
Correct.
oldnissanguy
2004 Mazda B3000 DS
Thanks!
