2019 everything lit up not starting
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
ISH604
Car: 2019 Infiniti QX50 Sensory in Hermosa Blue
2007 Infiniti G35X Journey in Liquid Platinum
Hey yall. Tried a topic before here. Only rogue one got back to me. Well here we are 7 months later. Been at the dealership for 4 days. They said it's some type of module problem. Anybody have this issue? Looking for any answer. Thanks for any ideas.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Might want to reference the previous topic or provide a more-detailed description. Lots of things can cause lights but no-crank.
ISH604
Lots of things can, but all of the light lit up and then the car doesn't start. No prior issues.
VStar650CL
Technical Expert
Security lamp lit? Brake lamps working? "Click" from the engine box? "Click" from under the dash but not the engine box? Key button cycles normally or just "On" and then "Off"? "PRNDL" indicator works normally? "Press the brake" message in the cluster responds normally? Most importantly, any codes in the ECM and BCM?
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
