2018 versa note IAC gasket? (rough idle problem)
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
talios
Car: 2018 Nissan Versa Note SV
Hello,
Hoping someone can help me with this, my 2018 versa note has started rough idling (drops to about 500 rpm and chugs every 20 seconds or so) before picking back up whenever the heat or AC is on. Google searching has led me to believe the likely culprit is a dirty IAC valve and while I've found none for my specific model it looks easy enough to clean on cars in general on YouTube, but they all mention there's a chance your gasket will break when removing it so make sure you have a backup. I've been searching and calling around for days and can't even find a part number for one let alone the part itself. Does anyone have any thoughts on if this is the right route to take and/or ideas on how to find the gasket? (I'm in Canada if it matters)
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's no IAC or FIC on an '18. Chances are you have a dirty MAF, a sticky throttle body, or both. Try the MAF first, it's a lot easier to access than the throttle plate.
Return to “Versa Technical Discussions”
