2018 Titan fuse location?
Covering the 2003-2015 first-gen and 2016+ Titan and Titan XD lineup
Genek
Car: 2018 Nissan Titan
Where is the fuse located for the sliding rear window on a 2018 Titan?
Reason: Revise title
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's no specific fuse for the sliding rear glass, power for all the windows is supplied from the BCM on a common bus. However, the rear glass does have its own circuit breaker, located at the righthand end of the dashboard near the inside fuse box. It will have a WHT wire going in from the BCM and a BLU/BLK wire going out to the sliding glass relays.
RicerX
Car: '20 Titan Pro4X
VStar650CL wrote:
Tue Jun 29, 2021 4:36 pm
Thanks for the solid answer here!
Return to “Nissan Titan Forum”
