Flashfox »
https://forums.nicoclub.com/flashfox-u131344.html
Sun Jul 12, 2026 1:35 pm
2018 Rogue SL, ~46,000 miles, always maintained at the Nissan dealership.
I need to go up to a mountain site every month or so. This location is at ~5600 feet. When I head there, I have no issues. However, when I return, I lose AC when I reach ~800 feet. It remains a problem until several hours or the next day.
I had brought the vehicle to the dealership to have it checked a few months ago and they found nothing as the AC worked.
Yesterday, on my way back from the mountain, I had the problem and drove it to the dealership. They had their AC main tech/manager come and have a look and he took pictures, notes and saw what was happening. I am scheduled to bring it back on Wednesday ... but as the AC is now working fine, I am, concerned that they will find nothing even though they saw what was happening.
Both CoPilot and ChatGPT AI platforms and the Nissan tech said that it looks like a pressure sensor as the problem goes away after a few hours as the pressure is equalized. He also speculated on something else as the air was cool BUT the airflow was practically non-existent, even with the fan at max (closed flap?). However, he did not understand why it would only happen on the way down and why it corrects itself the next day. Could be erroneous sensor info sent the the ECU? Note that this morning,the AC was working just fine.
I bought the OBDLink MX+ as it was recommended on CoPilot and ChatGPT. I also paid for the Nissan Enhancement, which is supposed to support the AC Pressure sensors. I hoped to look at AC high Pressure PSI and Voltage, and AC Low pressure PSI and Voltage, the Compressor control and environmental inputs (BARO, evap temp). I wanted to build a custom dashboard but those measurements were not available (sigh). And yes, the Nissan Enhanced module was purchased and the app confirms that.
So I now turn to this forum ... any ideas what "sensor" or issue could be causing this?
- AC works fine everywhere even when heading up the mountain to the ~5600 feet level
- AC fails coming back down when I reach ~800 feet level
- AC works again after several hours ... no issues any day even on very hot days
This all seems like a pressure sensor sending erroneous info to the ECU ... but which one?
