2018 Rogue phone mount?
ikalinin
Car: 2018 Infiniti QX60 Deluxe Tech
2018 Nissan Rogue SL
Hey guys,
Does anyone have any cool phone holder suggestions? I know they sell a nice clip that goes over the hazards button, but i feel like that a bad spot.
I'm looking for something that possibly attaches inbetween the trim and pass airbag? to the right of the radio.
Pref something that doesnt glue on.. do they have anything that slides into the little slit there?
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
ikalinin wrote:
Fri Sep 24, 2021 9:25 am
Hey guys,
I bought one of these:
https://smile.amazon.com/gp/product/B01 ... UTF8&psc=1
I have it in a different position but you can move it anywhere on the windshield. Works fine for me.
https://i.imgur.com/GuQWoFo.jpg
https://i.imgur.com/NYDAH9L.jpg
https://i.imgur.com/MYvxWyy.jpg
ikalinin
thanks for the pics and info.
yea, i saw those as well. but i would like something that is wedged, and maybe attached inside the slit in there vs gluing.
They used to make it for older Rogues. but i dont see the new gen product :(
i'm talking about something like this... but for a 2018.
https://youtu.be/4g1da437AWo
https://coursemotorsports.com/products/ ... 7926&_ss=r
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
ikalinin wrote:
Mon Sep 27, 2021 8:55 am
You can easily remove the leather panel next to the radio. That will allow putting a large magnet behind the leather for a strong magnetic mount, or making a neat hole to install a permanent ball mount that's retained from behind. Rogue center stacks are about the easiest to disassemble in the whole industry, you'll need a #2 phillips and a finesse tool (nylon pry bar). To remove that leather panel:
1) Pry out the A/C Control (no screws, just pawls)
2) Remove the righthand dash end-panel (no screws, just pawls)
3) Remove one phillips screw holding the righthand A/C vent, then remove the vent
4) Pry out the entire leather panel (no screws, just pawls)
ikalinin
those are some good ideas. Thank you!
D-Rock
Car: 2008 Rogue S AWD
2009 Rogue S AWD
2011 Rogue S AWD
2014 Rogue S AWD
I have the exact setup you're looking for in my Rogue. I bought a CD slot phone mount (I believe from MPow). The part that goes into the CD slot on this mount was a thin rubber blade (don't get the expandable ones). I cut off the rubber part and underneath it is a long, thin, metal blade. That thin metal blade fits very firmly in the exact gap you want to go into just by force-fitting it in. I then got a short 8" charge cable to go from the USB to the phone so I wouldn't have a long cord dangling around. The CD phone mount was under $20 (CDN). Much cheaper than the Pro Clips custom mounts that you can get and it's been perfect.
ikalinin
D-Rock wrote:
Tue Sep 28, 2021 11:02 am
can you send a pic of what it looks like in your car?
D-Rock
2009 Rogue S AWD
2011 Rogue S AWD
2014 Rogue S AWD
ikalinin
Oh wow! You are a genius!
It sits really snug in there? No issues?
I love it! Thank you
D-Rock
2009 Rogue S AWD
2011 Rogue S AWD
2014 Rogue S AWD
Thanks! I thought I was pretty clever figuring that out. It’s incredibly snug. It takes a bit of effort to slide it in but it’s never budged.
mmascari
Car: 2017 Nissan Rogue SL Platinum Reserve
I have not used this one. But, many years ago, I did use a similar mount from the same company.
https://pro-fit-intl.com/collections/ni ... e-g3-mount
It's similar to the CD Slot mounting adaptation, but meant for that exact same spot. Make sure to look at the directions PDF file.
I had similar from them on an old F-150 and Odyssey long before my Rogue. Just using a vent mount now.
Return to “Rogue Forum”
