2018 Rogue Panoramic Sunshade Retracts Completely
f1bud
Car: 2018 Nissan Rogue SL
The sunshade on my 2018 Rogue SL retracts completely before the moonroof opens. I want the sunshade to sync with the moonroof. Also, the tilt barely
opens. The tilt in my Kia Sorrento opened about almost two inches. Am I out of luck?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
f1bud wrote:
Sun Jan 29, 2023 10:21 pm
Am I out of luck?
On the syncing, yes. There's no way to change the motor software, it works the way it works. You should be getting at least an inch of lift past the skirt when tilting, so that might be a misadjustment. Try hitting the "tilt up" switch again after auto operation. If it moves up a little further then the stored auto position is incorrect and re-timing the mechanism will fix it. If it doesn't lift any further then it's at the mechanical limit and you're out of luck.
f1bud
Thank you for the tip on the tilt feature.
Return to “Rogue Forum”
