2018 Rogue Mystery Clunking Noise
Ericamcrosslin
Car: 2018 Nissan Rogue
This two months long saga all began when my boyfriend replaced the front right hub for me. Simple enough of a job. I drove the car for two days after and all seemed to be well. I went and bought 4 used tires. Upon leaving the tire place, which is a fairly reputable establishment, I noticed a clunking noise when making hard turns, and then again when straightening out. I could feel it in my steering. The tires are 225/65 R17 and are Michelin brand. I really don't see them being the issue, but now I'm questioning everything. The clunking happens after it's been driven for about a mile or so. So when something heats up, it's happening. It does not happen when I first take off.
We were first thinking along the lines that something else had worn, and that the old tires wore evenly with it, which is why I never noticed the clunking before.
The car is under warranty through MaxCare with car max, but I have a $250 deductible. I didn't bring it in for the initial hub replacement, because it was something my bf felt comfortable doing himself and could do for well under $250.
Because it was a mystery noise, I decided to go ahead and take it into a shop. We were leaning toward a bad cv axle, thinking that would explain the clunking and why the hub went bad in the first place.
While waiting for my appointment at the shop, I continued to drive it. However, one day, I took off from a stop light and smelt the most horrible burning smell and heard a horrible sound. I had the car towed back to my house.
The first shop looked the vehicle over for 3 days and found nothing wrong with it-nothing to explain the smell or horrible sound, let alone the mystery clunking. Upon paying the shop $90 for nothing and leaving, I figured out that my ac compressor wasn't working. That would explain the horrible sound and smell I heard just a few days prior. It was the serpentine belt burning bc the AC wasn't engaging. The shop did not want to work with the warranty company and ended up trying to charge me an arm and a leg out of pocket, past my deductible for the part.
I decided to take it somewhere else, since they also still couldn't diagnose the mystery clunking.
Fast forward a month, and two warranty inspectors later, a second shop has now diagnosed the mystery clunking as my transmission.
The second shop put a whole new transmission in and fixed the AC. They stated that I had a lot of corrosion on my right front cv axle and recommended replacing it. Warranty wouldn't cover it due to corrosion. We decided my bf would replace that himself. Upon driving the rogue home, I realized the mystery clunking was still there. I got a new transmission for nothing basically. There was nothing wrong with my old one. I have no idea how the shop managed to convince 2 inspectors for the warranty company that it was bad, because that obviously was not the issue, and it was still making the clunking noise.
We were thinking that due to the corrosion on the cv axle, maybe we were right in thinking the cv axle was the culprit all along. The only corrosion turned out to be that it was seized in the bracket holding it up. It took an act of God to get the thing out. Upon doing so, the differential seal broke. It also took a secondary act of God to find the correct differential seal. My bf finally replaced everything for me, and drained and refilled the diff fluid bc it had lost a lot of fluid during the seal replacement.
This POS is still making the clunking noise.
I need my car for work. I'm about ready to set the car on fire. I haven't been able to go in to work in 2 months because we don't know whats wrong with it, and I'm scared of the thing falling apart on me.
And honestly, at this point, we are out of ideas as to what could possibly be bad. 2 shops and 2 diy later, we still don't know whats wrong with the thing.
Ideas? Comments? Help. Please.
Rockhoundrob
Car: 2009 Nissan Rogue SL
Try looking at the subframe... push up on the front end and see if it moves up.
bushings could be bad.
Or check the control arms, swaybar links, etc...
By the way.. when you say clunk, is it metallic, metal on plastic, or metal on rubber?
worldbikr
Car: na
I had a mystery clunk noise while back. It ended up being drive shaft going out and it would make the back end of the car jump a little. New shaft solved it.
RickFlorida
Car: 2015 Nissan Rogue Select
So the transmission was replaced for no reason then? I'm kind of confused after reading this several times. The car drove okay but made a clunking noise and after a new transmission it drives the same but makes the same clunking noise? What did the shop say that replaced the transmission say was wrong with the transmission? That's a 5 to 8,000 dollar job, right? (finding a rebuilt CVT or replacing it and then the labor). There are sound kits the shop could have used to pin point the clunking noise before they replaced the transmission and would have saved you days/weeks and about 5,000 to 8K for your warranty company.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Personally 2018, that’s still kinda new to me. Should be a robust vehicle. Did your bf torque all the bolts to specifications. Moreover, was the vehicle’s weight on the ground when doing so.
If the vehicle was not settled and torque correctly maybe something is loose enough to clunk somewhere.
RickFlorida
You never really know but wow, a 2018 needing a transmission replacement is unusual. This is a crazy story for sure. Maybe it had 2 things wrong, a broken transmission but also a problem with other parts of the drivetrain causing the "clunking noise" which is why they still have it after the replacement?
That must be the only situation unless the shop defrauded the warranty company to replace a transmission unnecessarily.
Isn't it like 5 to 8 thousand dollars to replace a CVT even if it's re-manufactured?
(3,000 dollars for remanufactured CVT and 2500 for labor)?
It's difficult to find shops that are truly capable of rebuilding a transmission properly in my opinion.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
RickFlorida wrote:
Thu Sep 07, 2023 9:09 am
You're right that there must be some funny business in this particular instance, but it isn't a bit unusual for a 5-year-old CVT to need replacement if it isn't cared for. To any CVT, fresh fluid is life and dead fluid is death, full stop. The most foolish thing Nissan ever did in their whole 112 year history was the "lifetime CVT fluid" fiasco, and for very bad reasons, they still refuse to recommend proper maintenance in their OM's. Prematurely-dead trannies are the natural result of that misguided policy.
:mad:
D1dad
Car: 2021 Nissan Altima SR
2018 Nissan Rogue Midnight
2009 Nissan Altima SL
I’m still dealing with this on my 18 awd and have been for 80-90k. It seems like since the weather has gotten really cold, that it’s gotten worse. I thought it was due to running in eco mode but that wasn’t it. I’ve done no less than 10 cvt refills and just dropped the pan and changed the filter and have done that pita cartridge filter as well as several transfer case and rear differential services. I can’t see any bushing worn anywhere and would think that in the last 5-6 yrs, whatever it was would have broken. I’m at a loss Vstar?
VStar650CL
Technical Expert
If you mean something is clunky, if it isn't the transmission or north then it's probably in the transfer or south. You can implicate or exonerate the transmission by watching the solenoids with CVTz50, if something changes that correlates with the clunk then you probably have a smoking gun.
D1dad
I think it’s the control arms. It sounds like drive train has slop when you let off the accelerator at low speeds or blip the accelerator. I had Nissan look at this a few times under warranty and no luck. They couldn’t just start throwing parts at it with no clear culprit. I’m now at 121k and it’s just the same as it’s always been. I saw someone post of Facebook who had the same issue and coincidentally replacing the ball joints ended what he’d dealt with for years. My seals are good and no issues with my ball joints so haven’t crossed that bridge yet.
D1dad
How big of a job is the transfer case hour wise? I bought a new one for a decent price. I had this car at the dealer several times for the clunk when it was under warranty. I can’t say that it’s ever gotten horrible but does seem to be getting worse around town. The car itself is immaculate and has been cared for to the point of being neurotic. It’s paid off and the engine and cvt are tight. Every cvt service reveals crystal clear fluid and I don’t burn a drop of oil in 5k.
VStar650CL
Technical Expert
It's 4~5 hours in a shop, so you're looking at an all-day job in a driveway. It's driveway-doable though, not like yanking the engine or transmission.
D1dad
Thanks vstar. Just looking at things underneath, it doesn’t appear that outside of gear oil, I wont need any other parts? Is there any gaskets or odds and ends I’d need?
VStar650CL
Technical Expert
Nope. The xfer and transmission have their own seals, so even though they're bolted to one another, the only thing shared is the shaft. Unless you have issues with something unexpected, oil should be all you need.
VStar650CL
Technical Expert
PS - On the gen2's you do need to lower the subframe for the axles to clear (kind of a d*** setup). Be prepared with jacks and supports for doing that.
D1dad
I may end up using a local shop since I have no lift. If you get a chance, can you let me know how many hours you’d bill for this job? Just so I have a gauge of being ripped off or not.
VStar650CL
Technical Expert
I'm sure your rides aren't rust buckets, so nothing extra for the condition of the car. I'd say more than 6 means they don't know what they're doing.
Return to “Rogue Forum”
