I own a 2018 Rogue SL and overall I like the car. HOWEVER, there has been an issue that nobody seems to be able to fix. The car constantly misfires if below 2500 rpm and the check engine light is always blinking. The car also vibrates heavily during idle and jerks when driving. It sounds louder than a diesel engine and you don't have to be a car expert to know that something is off. Once you exceed 2500 rpm though the engine will become absolutely smooth again and the check engine light stops blinking (it will just stay on because there is obviously some fault codes saved). Acceleration and power also seem to be fine. After dropping below 2500 rpm for a few seconds it will blink again...
When we bought the car in late 2019 it ran well. After a while we got a check engine light and took it to the shop. It was just a "Cylinder X misfire" and it was deleted. Weeks later we had the same fault code again. The spark plugs were checked and the code deleted. Ever since then it got slowly worse. Now the car drives "reliably" but it's misfiring like crazy when the rpm is low. It's extremely annoying and I wonder how much damage it does to the rest of the engine and transmission parts. We moved overseas and took the car with us (when the issue still seemed to be little at the beginning of 2020) so our warranty is void unfortunately. (I wish I could just ship it back to Japan and get a refund...)
I took the car to a local Nissan dealer and here are the things that have been checked or replaced and that seem to work properly:
- spark plugs
- ignition coils
- air intake leak
- sensors: MAF, crankshaft pos, camshaft pos, knock, oxygen
- cylinder compression
- fuel injectors
- fuel pressure
- alternator
- reset ECU
- replaced timing chain and tensioners
I know the theory of how the engine works since I am a Mechanical Engineer and I work with engines on a daily basis (although diesel). However, this issue is driving me insane and I don't know what else can be tested or replaced. I am slowly becoming desperate
Is here anybody who may have experienced something similar? Is there anything else that I can check that I may have missed? The only thing left that I can think of is the CVCT (valve timing system) which consists of three identical VVT solenoids. Is it possible that one (or multiple) of them is not working properly and causing all my issues? But why wouldn't it show any other fault codes then?
I appreciate all replies and suggestions! I just hope you guys can help me!
Cheers,
Manuel
