VStar650CL, I could use your expertise... the Rogue has been leaking and water has been seen in the A-pillar on driver's side-I'm guessing this is a clogged drain and will address that problem in the coming days. Sadly, it sits in the elements of TN while my kid attends college. Upon being home for break, it sits outside as well. We found water, a significant amount, in the floor of the passenger's side. It hasn't been raining much and no snow. Could the water in passenger's side still be leaking moonroof (clogged drains)? Or could it be a clogged A/C hose/Heater core issue? Finally, is there a video or an assembly book on how to remove the carpet to clean and air the carpet? Any recommendations is appreciated.VStar650CL wrote: ↑Wed Aug 10, 2022 12:55 pmYou're most welcome. That one section that didn't seat all the way is probably from some deformation of the ribs, but Gorilla Snot is good stuff and may hold it. Keep it lubed periodically with some wet silicone on the outside and it won't stick to the rear glass as readily, that will help a lot.
By everything else, are you talking about the plastic door sill plates/molding along the door? What is best way to remove the molding/sill plates? Any special tools required?VStar650CL wrote: ↑Wed Dec 28, 2022 8:14 amVis the carpet, you'll need a T50 torx driver to remove the passenger front seat and a 14mm to loosen (but don't remove) the rear passenger seat. If it's Bose audio then you need a 10mm for the amp under the seat. Everything else just pops loose. Lift the carpet as high as possible and bungee it to the center console. There will be plastic plugs in the floor for standing water, but they're sealed in. Don't try to remove them, poke or drill holes in them and then cover with self-stick foam when it's dried out. Treat the undercarpet and the foam spacers with Lysol with Bleach before you dry them out, mold is only dangerous when dry. If you find any black mold, don't screw around, get some N95 masks and replace the carpet. Green, brown or white mold are all treatable. There are usually plastic bags over the foam spacers, remove and discard the plastic.
VStar you make it sound so easy. 30 minutes-I'm planning a whole day. Can I just hire you? LOL I'll keep you posted. Thanks!VStar650CL wrote: ↑Wed Dec 28, 2022 9:20 pmNo, the sill plates will pull loose with your fingers. So will the lower B-pillar trim, front kick panel, and front console kick panel. The front kick panel has a plastic nut. The B-pillar trim has a slot with a plastic key for the seatbelt to pass through, so there's no need for the belt to come loose. There will be two carpet retainers underneath the passenger seat, those pry out with a screwdriver inserted from the side. The carpet is split underneath the rear seat, so you only need to remove the front bolts and loosen but don't remove the rear ones, then the seat can be tilted and the carpet pulled out from underneath. The only tricky part is the front spacer, there's a duct that runs across it into the console. I don't usually bother removing the duct, I just cut the spacer into 3 pieces and then duct tape it back together when I reassemble. Altogether it isn't a hard job, with a power ratchet I can have one stripped and lifted in under 30 minutes.
Well that is alarming! I'm guessing the cleanliness of the water is because it has been filtered by the insulation and carpet? The water isn't too dirty. Granted the water that we sucked up with carpet cleaner on top was dirty. The FL humidity is making the drying process take a few days. We finally have a sunny day and we have put the car out in the driveway with the other pieces in the sun to bake and dry. We are likely to need an additional day for drying it out before a once over with more bleach and then the reassembly. Hopefully, we can recall where everything goes-lol.VStar650CL wrote: ↑Sat Dec 31, 2022 4:28 pmThe trouble with clogged drains is that you can have 2 gallons of water in the floorboasrd before you even realize there's a problem, and the plastic laminate in the carpet keeps it from evaporating. So yes, that's entirely possible. I once had a Rogue show up with white pond scum growing in the floorpan because the water had been there for so long.
Things are finally about dry, so thanks for your help. Another question, when reinstalling the seats, are there torque specs to set the screws to? I used a torx socket/ratchet to remove them, but I want the seats to be safely installed.VStar650CL wrote: ↑Tue Jan 03, 2023 5:08 amYah, but only the undercarpet. It's color fast to the top side or upholstery if you overspray. Other formulations may be color fast too, but I can't vouch for them.
No worries. Just tightened it down to the point of unable to do more. Your help made the process not so overwhelming-I thank you.VStar650CL wrote: ↑Thu Jan 05, 2023 5:32 amThere probably is a spec but I don't think Nissan pays attention to it, we see factory bolts that are all over the lot in tightness (even across the same seat). I just take them all the way down with a power ratchet (probably 30 lbs/ft) and then give the ratchet an extra yank with arm power.
