2018 Q60 XM cutting in and out. Known issue??
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Only have 11K on her, but now the xm is cutting in and out more and more. Not an issue at all with the 2018 4Runner.
Thought I would check in here before calling the dealership.
Thanks!!
:cheers:
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Not sure what part is used on your Q, but we have seen some issues with the XM antennas on the new Altimas. If it's the same part then chances are the antenna is bad.
VStar650CL
Technical Expert
PS - You should have OTA update for the AV Unit on an '18. If you haven't done it already, connect the car to your home WiFi and make sure you have the latest firmware update. If not, that may fix it.
SVTCOBRA
Thanks, will check in with my friend at the dealership.
Return to “Infiniti Q50 / Q60 Forum”
