VStar650CL wrote: ↑Sun Mar 05, 2023 5:56 pm
Not the big terminal on the alternator, just the smaller plug. It won't charge because the fields will be disabled with the connector loose, so yes, only run it for a short time.
Alternators aren't supposed to mind getting wet, so if washer fluid did it in then there was something wrong with it anyway.
I ran a few tests like you said. When I unplugged the alternator sensor like you said, the 2nd picture is the results I received for 2-3 start ups in a row. When CEL is off, it only shows the 2 codes with weird characters at the end (pic #2).
Here is an example of what my code reader shows normally. The CEL is ON and it show's this
Here is an example of what shows when I unplug the alternator sensor, put the shutter flaps in the down position. The CEL is OFF but the code reader shows these codes.
I am thinking buying a grille shutter assembly is the best move? Nissan Part #21421-4BC0A. There seems to be a few $200 new chinese aftermarkets available. A genuine OEM nissan is about $400-450. Do people have good experience with aftermarket versions of grille shutter assemblies other Nissans?
In your experience? Should the other codes the mechanic mentioned be showing up on my cheap code reader? It appears the grille shutter is the only one I can see.
Thank you so much for your input again!!
