CBF87 »
https://forums.nicoclub.com/cbf87-u284895.html
Wed Sep 26, 2018 3:54 pm
So I think I figured out why this happens...or at least I'm able to reproduce the problem at will. What I have discovered is that if I have the head unit on MAP display OR Main Menu with a MAP 'plug in" when I turn my 2018 Rogue off, the map zoom is zoomed out. If, however, I change over to, say, AUDIO before I shut down the car this doesn't seem to happen ....caveat...if I wait about 30 seconds after powering car on before changing to maps view. What I'm guessing happens is that until your unit can get a GPS LOCK it has no idea where you are and zooms out to the appropriate level, which at power on in my case was a globe view. Also, if I only waited a couple of seconds after start up, it would be zoomed in on, say the eastern US. So, again, I'm thinking at power one your set to zoom level 5...but your GPS isn't fully locked so your GPS "accuracy" is nowhere near that level so it zooms out to the "accuracy" that it had at startup. Since I have been changing the view over to the AUDIO source before turning off the car, I no longer have the zoomed out issue. Anyway...hope this helps.
