2018 Armada Need Help! Cluster Alternator Charge Issue
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Nvitro
Car: 2018 Nissan Armada SL
Hello, I hope someone can help here!
I have a 2018 Nissan Armada SL that has the all to frequent led backlighting issues on the speedometer cluster and I took it out to send it off for repair.
I sorta assumed that the vehicle would still be drivable with no cluster, but I realized there was a chance it may not due to the way they make some cars these days.
I figured it would be obvious after I removed the cluster , it would start or not, but I was wrong.
After I pulled the cluster, I pressed the start button, and voila - it started right up. Slight hiccup, it did not shut off right away with another press, but I found it did shut down when you press and hold the start button.
Bigger hiccup, which I did not find until about 4 miles away when it died in the middle of a busy intersection and I had to have it towed home. Apparently, it had been running on battery only, as near as I can figure the computer had shut down using the alternator to charge the system, or never allowed it to anyway.
My question- in another thread I saw others talking about clipping a wire to solve some other charging issue, and do we think there is any chance this would resolve this issue and allow me to drive the car until I get the cluster back, or do I just need to rent a car?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That's a software issue, so I can't say I know why the IPDM would shut down charging just because the cluster was offline. There are so many processors talking to one another on a typical Nissan, it's often impossible to understand why a particular unit does what it does in response to a particular failure. That said, the alternator is "on its own" when that PWM wire is clipped, so that should fix the problem.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
