2017 Rogue model differnces between the Canadian and USA versions
fernarch
Car: 2017 Nissan Rogue SL
Just bought a canadian version of the 2017 Rogue. Can any one tell what differences are between the US and Canadian versions.
mpattdu
Car: 2008 Nissan Rogue SL AWD
Back when the Rogue first came out one of the first moderators for this forum was a Canadian and he put together a list of differences. It's in the FAQ Sticky but only includes 08-09 model years. However, many of the differences are probably the same such as Canadian Rogues equipped some some cold-weather goodies as standard equipment like engine block heater and side mirror defroster. Much has changed in 10 years, though, so you might just need to reference the FSM spec sheets like he said he did to compare for yourself. Here is the old thread: rogue-model-differences-canada-vs-us-mo ... 25256.html
fernarch
Here are the things I’ve found that are different from the brochure comparisons. If anyone else knows more differences - please posr them.
1. The speedometer is slightly different than the US version. Still shows mph as the dominant speed but is not as detailed.
2. Passenger seat is 4-way power on the SL model.
3. Has a 12.0 capacity fuel tank vs the 14.5 on the US version.
PRS247
fernarch wrote:
Fri Mar 09, 2018 5:07 am
If I could see yours, I could probably point out any differences. Do you have any videos of it on youtube?
fernarch
No I don’t have any videos. Do you have one of these too?
CapeCodChips
Car: '14 Nissan Rogue SV Gun Metal Grey
fernarch wrote:
Sat Mar 10, 2018 5:49 am
Gas tank is the same size for both.
Canada will describe volume in liters, or (Imperial) gallons, which are about 20% larger than a US gallon.
JPack
Canadian models come with:
Low windshield washer fluid warning light.
Engine block heater.
17RogueS
Car: 2017 Rogue S FWD
2013 Rogue S FWD Special Edition
I noticed some of the packages are different too. I’ve got the Rogue S with an appearance package but it doesn’t have the chrome door handles or tinted windows that are listed on the American version.
mitchrogue
Car: 2016 Nissan Rogue
FYI. the speedometer has km/h dominant and the tank is the same size, our gallons in Canada are just bigger.
ras_oscar
Car: 2012 Nissan Rogue AWD
CapeCodChips wrote:
Tue Mar 27, 2018 4:51 am
So a 14.5 US gallon tank would be a 12 UK gallons. Kewl I never knew that.
Return to “Rogue Forum”
