2017 Rogue liftgate
STT
Car: 2017 Nissan Rogue SL AWD
2017 Rogue SL AWD. Power liftgate will chime/activate and open 2-3 inches before reversing and closing. Activation with fob or button on the dashboard. The liftgate can be opened manually and will stay open without sagging. No chime and unable to activate closure of the liftgate with either the fob or dashboard button. No change with resetting the fuse for the liftgate.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2012 Honda CR-V LX
2022 Honda Pilot Special Edition
2017 Nissan Rogue liftgate reset
STT
Unfortunately that doesn't work, either
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If the reset won't do it then chances are you have a bad encoder in one of the struts. You'll need to get codes out of the ABD Controller to find out what's wrong.
Return to “Rogue Forum”
