2017 Rogue FSM?
plhoff
Car: 2017 Rogue S AWD
New member. Really enjoying the data, stories, and info for our car here. Looking to change out most of the fluids myself. I'm concerned about using the right brands as I've read that not all are created equal or compatible. I realize that using genuine Nissan is ideal but it's not ideal not for my wallet. I found the FSM for 2016 Rogue but couldn't find 2017. Will 2016 be the same as '17?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Yes and no.
For 2017, the hot-selling Nissan Rogue offers a freshened exterior look, enhanced available safety and technology – and a new gasoline-electric powertrain (late availability). Following is a brief overview of some of the major enhancements. Equipment availability may vary by grade level and equipment package. 2017 Rogue versus 2016 Rogue
datechboss101
Car: 2016 Nissan Rogue SL -- RIP
2018 Nissan Kicks SR -- RIP
2019 Nissan Rogue SV w/ Prem. Pack
I have the FSM for the 2014-2017, as they are similar in parts. PM me for the files.
plhoff
Thanks datechboss101. What brands are you using for fluids? I'm really interested in transfer case and differential. Was thinking about using liqui moly which I found here: https://www.amazon.com/dp/B001NFC1BM/re ... LBb7TYCGEB
datechboss101
For fluids it doesn't matter what brand you use, ONLY IF the fluid is the correct SPEC that works with the vehicle. Typically I use OE fluid (Nissan, Honda, Acura, etc) for the respective vehicle.
plhoff
datechboss101 wrote:
Sun Sep 09, 2018 11:29 am
Totally understand that OE is the best to use as it's 100% compatible but I mention in my opening post that I'm looking for an OE alternative as it's not the most economical or in some cases, even available. I'm curious as to what others use in their Rogues, especially for my year, 2017, or equivalent.
Chuckh
Car: 2017 Rogue SV
Liqui Moly is a very good brand but I have never tried their gear oil or transmission fluid. I have a 2017 with 30,000 miles. I have never done anything other than oil changes on this. Could someone point me in the right direction for changing the differential and transfer case oil as well as the CVT fluid? Really the Rogue is my mother's vehicle. I drive a 2013 Passat and have changed the fluid in it (despite it being "sealed"). My mother does not know much about computers so I do this for her.
bnwitt
I would really like to obtain the FSM PDF for the 2017 Rogue if anyone knows where to find it.
thanks
Rogue One
2022 Honda Pilot SE
bnwitt wrote:
Tue Nov 03, 2020 5:36 am
thanks
Management is looking into updating the FSM section. Nissan North America (NNA) revamped their sections for manuals which has complicated matters, not to mention that we also have to pay to access them. Unfortunately there isn't a date yet on when this will be completed, so just keep checking.
If your need is urgent, you can pony up $19.99 and get a one day subscription to view the 2017 Nissan Rogue Service Manual online from NNA. Or for a mere $210.00 you can get a copy sent to you on CD.
In the meantime a lot of the info in the 2016 Rogue FSM will still apply to your car.
bnwitt
Thanks for the reply Rogue One. It's hard to believe Nissan wants so much money for the FSM
datechboss101
Rogue One wrote:
Tue Nov 03, 2020 6:10 am
thanks
Not as bad as how much Honda is asking just to have a day access for their manuals!
Return to “Rogue Forum”
