2017 qx50 sonar not working.
jaxquest
Car: 2010 Murano LE
I could use someone’s help. It's a 2017 Infiniti qx50 the car has sonar. Under the camera screen the sonar is blacked out. As well as towing and show camera when sonar activates. The car was hit in front and complete front bumper needed to be replaced. The rear bumper just needed to be reattached. Not sure if bad sonar. Small piece of harness missing from right side from sensor to washerbottle area. and the shop made the connection work. But sonar still not working. Al cameras work I give up. The cruise works but the distance don’t
audtatious
If this was a collision that was fixed under insurance then it's up to the body shop to make sure all systems properly work. Contact them and have them fix it. If they won't then contact your insurance company about the issue and let them deal with the body shop. If you paid out of pocket and don't want to pay Infiniti to fix it then you will need to go through the FSM and trace/validate each component, starting with the sonar sensor in the front.
