2017 Q50S DAST problems doesn't work
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
Chevy29
Car: Infiniti q50
Hello!!! My name is Alex and I am contacting you from a repair facility in Northeast Philly. We have here 2017 Infiniti Q50S with DAST steering with liht body damage (no deployed airbags, no chassis damage) after we fix all body damage it was no faults lights an the dash and everything seems working good. As part of repair we supposed to check alignment and fan part begins. We have Hunter alignment machine and when we started procedure and adjusted front right toe (was out little bit) Hunter recommends to perform DAST1 and DAST2 calibration. We used Autel tool to perform procedure and when I started DAST1 of course wheels turns left then right and I heard click sound and power steering doesn't work now and I have a lot of codes.
My codes:
ABS: C1138 4WAS CIRCUIT
ICC/ADAS: C1A04 ABS/TCS/VDC CIRC
Chassis control: C1B90:00 DAST SYSTEM (NO SUBTYPE IMFORMATION)
DAST1: C13E9:00 BOOTING ANGLE PROCESSING
C13EB:00 BOOTING ANGLE PROCESSING
C13F0:00 INCOMP DAST CALIBRATION
DAST2: C13EB:00 BOOTING ANGLE PROCESSING
Tried to repeat DAST Calibration and Autel tool showed massage that " condition not met error 22 (DAST1 and DAST2 the same)
After couple hours with Autel I found in the data strange numbers:
STEERING PINION ANGLE: 6.8 (CHANGES WHILE ROTATING STEERING WHEEL)
STEERING PINION ANGLE 1: 117331.9 (CHANGES WHILE ROTATING STEERING WHEEL)
ANGLE DIFFERENCE: 117333.1 (STAYS THE SAME WHILE ROTATING STEERING WHEEL)
According, truthfully only my intuition, I think we can't repeat DAST Calibration because of the angle difference and that crazy numbers of 117333.1 something, degrees probably. We left car to the dealer and they tried to reset codes and calibrate DAST but unsuccessful and they told as the vehicle need to be relapsed major DAST components.
Maybe someone can help as in that situation, or maybe recommend as in which direction we should dig.
audtatious
Not sure but it sounds like a cluster-fuk. If Infiniti can't reset it through CONSULT and state there are now parts to be replaced then that's the way to go. I've not had alignment issues from my car yet but did have the system go nuts once with the steering wheel cocked 20 degrees....after a couple minutes, and a U-turn, it fixed itself and has been fine.
Nighilanth
Car: 2014 Infiniti Q50 S
Hi! Did you fix the problem and what did you do?
DAAN.
Am new around here - hope this will; Help you : )
What you're experiencing is an uncalibrated DAS
The calibration process is:
Turn off car (~30 secs), Turn back on
Make sure wheel is centered
Turn 90' to left, 90' right and repeat a few times (I did not stop at center)
Pull out onto road, get her up to about 40-45 mph and hold car center. DAS will re-calibrate in a few secs. Make sure road is straight, not bumpy
Good luck from all of us
Nighilanth
That didn't help :(
cgauto
Car: 2020 Infiniti Q50 S
I know this was a long time ago since you posted this but I have the same exact problem on a 2020 Q50 I was wondering did you ever resolve it and if you did what was the fix
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The fact that the OP heard a click when the problem happened makes me suspicious that the system popped a fusible link and one of the motors or controllers went unresponsive. On all the DAST's I've worked on (admittedly not many), only the Force Control module and sometimes the Main Steering module talked to the CANbus. One or both Steering modules were on a separate Flexray bus to the SF module and didn't communicate directly with the VCAN. That meant you could get all sorts of weird responses and codes when power to one or more of the modules went down. Each steering module should have its own fusible link (probably 100A), and the SF module should also have a link plus a separate 10~15A ignition fuse. Start by checking all of them, and make sure all 3 module grounds are secure.
Return to “Infiniti Q50 / Q60 Forum”
