2017 Q50 Key FOB battery dies quickly
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
josney
Car: 2017 Infinit Q50
As the title reads, I own a 2017 Q50 3.0t that the key fob battery only lasts about a month. At that point, we get the message "incorrect Key ID". After placing the key fob on the push button, I can start the car.
Anyone experiencing this? Searched the forum and really got nowhere.
josney
303 views and not 1 response? well, other than my own
audtatious
I've had these style key fobs since 2007 on 4 different cars and have never had a similar issue. Could the buttons be getting pressed when in your pocket?
josney
no Sir. We bought the car used and only received 1 Fob. My wife carries the key fob on a lanyard around her neck on her job. Other times the keys are in the center console or hanging up at home.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Problem is probably within the key fob circuitry causing the battery to drain, might need to replace the key fob
telcoman
josney wrote:
Mon Jul 29, 2019 4:34 pm
Why?
All Infiniti's purchased at the dealer come with two.
I'm assuming that you purchased from a non Infiniti dealer and they screwed you with a non OEM Fob?
If you did purchase from an Infiniti dealer go back there and request two new OEM Fobs
Telcoman
josney
maybe I should have mentioned we bought the car used from a local Nissan dealer. FOB shows Infiniti
audtatious
You can buy another similar new fob online and have Infiniti cut the key and reprogram to your car. It will probably cost you around 125-ish for the key cut and reprogram.
Return to “Infiniti Q50 / Q60 Forum”
