2017 Nissan Rogue transfer case oil fill plugs?
johnnyblack23
Car: 2017 Nissan Rogue SV
So I enjoy doing most, if not all routine maintenance on my wife's Nissan Rogue. Recently @ 54k I have changed the CVT fluid (first time). My plans were to change the rear differential oil and the transfer case oil. Well I quickly realized that my Rogue doesn't have a rear differential for me to change the fluid in, guessing due to the fact that this isn't an AWD Rogue. When I went on to attempting to change the transfer case oil in the front, I couldn't find the drain and fill plugs! I looked at videos on YouTube and tried to find diagrams, but could not find much. From the limited videos I found it looked like there should be 2 bolts that require a 10mm hex to remove. Can someone please help steer me in the right direction, please?
Reason: Revise title
D1dad
Car: 2021 Nissan Altima SR
2018 Nissan Rogue Midnight
2009 Nissan Altima SL
No transfer case on a FWD. The CVT fluid is it.
D1dad
I’d also do another cvt service if you waited till 50k to do the first. Another service would have you replacing about 75% of the fluid. I did 2 drain and fills at 40k and will do them every 10 after. Eneos N3 is essentially the oem fluid or idemitsu.
Return to “Rogue Forum”
