Rogue Jarhead »
https://forums.nicoclub.com/rogue-jarhead-u216599.html
Fri Jan 06, 2017 4:07 am
A shaking steering wheel is often one of three things. Bad tires ,bad axle or bad steering parts
1. The tires are out of balance or you have a broken belt. You can test this by rotating the tires front to rear and rear to front, then take it for a drive. Has the vibration changed or gone away? If so then go get the tires rebalanced. Depending on where you are this is the time of year when you drive through deep snow and sometimes it accumulates on the inside of these fancy aluminum rims and causes a balance problem. Once it melts the vibration goes away.
A broken belt can often be felt by running your hands over the surface of the tire. You will feel a lump or bulge, in this case you will need a new tire(s).
Even though you have said the vibration is only at certain rpms, I know you're thinking worse, transmission for instance, but I would want to rule out the simple first. Out of balance or tires with a broken belt cam cause weird problems.
A friend of mine bought 4 new tires, after mounting and balancing his van had a slight steering vibration only at 70 mph nod above. He went back 3 times to the tire store, they finally found that one of the tires had a bad belt.
2. Worn tie rods , wheel bearings or ball joints can cause a vibration. Jack the car up, grab the tire with your hands at the 3 and 9 o'clock position, attempt to move the tire. If it moves you have a suspect tie rod. It's a good idea to have some one hold the steering wheel as the steering wheel will move slightly even though it's locked.
Grab the wheel at the 12 and 6 position, attempt to move it pushing and pulling. If it moves your wheel bearing is suspect.
These usually don't happen on a new vehicle.
3. After all else an axle can also be bad. Does the vehicle make clicking noises when turning right or left. Are the rubber boots covering any of the 4 cv joints split and puking grease all over from high speed spinning?
After having said all this, on a new 2016 vehicle the first thing I would suspect is the tires. The dealership should be able to rebalance or replace them. All the other items are for older vehicles with a few miles on them. Unlikely to be a problem for you....yet.
And of course I think from your description that you suspect the transmission, and it could be , there have certainly been enough CVT failures. Make sure the dealer documents everything so you don't get down the road and out of warranty, and have no recourse if the transmission does fail.
What harm can contacting Nissan do? Ok so they blow you off, at least you tried, and maybe they'll step up and help out.
