dave_wstwd »
https://forums.nicoclub.com/dave-wstwd-u299491.html
Sun Dec 20, 2020 9:20 pm
Thank you “Rogue One” and “Lone Wolff” for your responses. Much appreciated. I think we found the issue and resolved it.
Using the Oil change indicator for example, there are two mileage fields, the accumulated count, and the mileage limit. For example, a car with 100 miles into a 6000-mile oil change would be displayed like so: 100 / 6000.
As you probably know, the mileage limit can be adjusted up or down as desired. Unfortunately for my unsuspecting friend, the mileage limit was set to zero.
The display looked like _ _ _ _ / _ _ _ _.
Effectively, this disables the service indications. They will never trigger oil change service needed. My friend drove the car and never was flagged to change the oil (yes yes, I know. A gracious lecture was provided).
After putting a value in the mileage limit (for the right hand field), things seem to be working properly.
It’s nice that Nissan gave the flexibility to change the mileage limit. However, they have given their customers enough rope to hang themselves unfortunately.
Anyway, for what it’s worth, here is what we did to deal with 50,000 mile old motor oil.
1) Drained the oil (thankfully, it did “drain”, but was a bit sluggish).
2) Replaced the oil filter and put in the most inexpensive 5/20W oil we could find, along with the controversial STP engine flush.
3) Ran the car for 10min
4) Drained the oil
5) Replaced the oil filter again and refilled w/ Mobil 1 0-20W full synthetic
6) Set the oil change indicator to 1,000 miles.
Our plan is to use STP engine flush for this next short cycle oil change in 1,000 miles.
Oh my.
