2016 rogue s fog lights
Karkourkaka
Car: 2016 Nissan Rogue S
My question is 2016 Nissan Rogue S pre wired for fog lights installation?
If yes how I know?
Frzninvt
Car: 2021 AWD Rogue SL w/Premium Package
Champagne Silver
They all should be prewired the problem is you have to remove the air bag and steering wheel to put the new stalk control in. I would not be brave enough to attempt it.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
not all cars are prewired. remove the bumper or get behind it somehow and see if there are plugs there. odds are there are none.
Meynardo
Car: 2015 Rogue SL AWD
I believe there is already a discussion about this
adding-oem-nissan-fog-lights-to-the-rogue-t381893.html
Check it out, you will surely find a lot of good info if you decide to have it done.
Frzninvt
Champagne Silver
ImStricken06 wrote:not all cars are prewired. remove the bumper or get behind it somehow and see if there are plugs there. odds are there are none.
Do you honestly think Nissan would spend extra money on creating different a wiring harness for each trim line (S,SV & SL)? They make one harness because it makes economic sense, so the wiring will be there.
ImStricken06
2016 Kia Sorento
Some cars do, some dont. Right? So go find it
brandoha84
So my local Nissan dealer was doing a buy one get one incentive based offer and my wife got a '16 Altima 2.5 SL and I got the Rogue base model... Coming from a fully loaded Altima SE it's a bit of a change... Not even having fog lights, it's a bit of a downgrade but being my old Altima was 11 years old it's still nice with standard features being quite nice nowadays. My question is this. I did some searching to actually add fog lights and I was of course directed to ebay and saw some kits there, some much cheaper looking and some OEM kits with new light stalks and all for a reasonable price, same price as courtesyparts.com so not bad considering you get the stalk and everything but I'm curious if any other base model owners have added any, where they got them? Price? Is there a better aftermarket solution than OEM? Also I noticed these factory Nissan parts don't come with wiring is it there just not hooked up? Also what else has anyone upgraded the base that didn't come with it from the factory? Thanks in advance ladies and gents!
(Log time member lost my old username and password and don't have the email anymore so created a new account. Oh well!)
FantomLightning
Car: 2015 Nissan Rogue Select AWD w/ Convenience Package.
Graphite Blue
To answer the question about wiring. If this is like the first gen Rogue as well as most other Nissans, and lots of other Jap cars, everything should be prewired. Just swap the stalk, connect the fog lamps to the wiring (normally taped up somewhere out of the way), and mount them.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
brandoha84 wrote:So my local Nissan dealer was doing a buy one get one incentive based offer and my wife got a '16 Altima 2.5 SL and I got the Rogue base model... Coming from a fully loaded Altima SE it's a bit of a change... Not even having fog lights, it's a bit of a downgrade but being my old Altima was 11 years old it's still nice with standard features being quite nice nowadays. My question is this. I did some searching to actually add fog lights and I was of course directed to ebay and saw some kits there, some much cheaper looking and some OEM kits with new light stalks and all for a reasonable price, same price as courtesyparts.com so not bad considering you get the stalk and everything but I'm curious if any other base model owners have added any, where they got them? Price? Is there a better aftermarket solution than OEM? Also I noticed these factory Nissan parts don't come with wiring is it there just not hooked up? Also what else has anyone upgraded the base that didn't come with it from the factory? Thanks in advance ladies and gents!
Topic merged with existing thread. BTW, if you have log in problems, you should send an email to the webmaster. Your old account could probably have been found by looking up your old email address.
brandoha84
Thanks Rogue One! I'll do that as well!
brandoha84
FantomLightning wrote:To answer the question about wiring. If this is like the first gen Rogue as well as most other Nissans, and lots of other Jap cars, everything should be prewired. Just swap the stalk, connect the fog lamps to the wiring (normally taped up somewhere out of the way), and mount them.
I had assumed that being most cars have one harness, and like you stated the extra wiring taped out of the way, just looking to see if there was real world experience. Thanks for the help!
Antndrew78
Car: 2001 Nissan Pathfinder le
I just bought a 2016 rogue sv awd and want to install fog lamps when I did a search on ebay there were a lot of kits available that come with the bezels and all the wiring the pricing was 50-80 wanted to know if anyone has purchased these and if they were any good as far as quality or should I just stay away thanks
Rogue One
2022 Honda Pilot SE
Antndrew78 wrote:I just bought a 2016 rogue sv awd and want to install fog lamps when I did a search on ebay there were a lot of kits available that come with the bezels and all the wiring the pricing was 50-80 wanted to know if anyone has purchased these and if they were any good as far as quality or should I just stay away thanks
Merged with existing thread.
K03sport
Car: 04 Pathfinder. My first Nissan was a '72 Datsun 510 Wagon.
if the car is not pre-wired, why not just run your own wires and relay and then use a blank spot on the center stack or console to mount the switch.
even if the kits come with the stalk, there is nothing that says you have to use it. of course if you don't use it, you will need to run your own wires and relay.
It is a fairly simple job with the hardest part maybe finding a gommet to pass wires through the firewall.
how useful (beam pattern wise) are the stock fog lights anyway? I mainly use mine when it is raining out so I can see the lane lines. Fog really isn't a problem where I am at.
Return to “Rogue Forum”
