I also find that my fog lights are aimed really low. How did you adjust their aim?mjs1444 wrote:I just got my 2016 Rogue SL AWD 3/5/2016. I puled the factory bulbs , low beam and replaced with Sylvania Silver Star Ultra. I also had to raise my fog lights as they were aimed really low. What a difference this makes !
Much better
Thanks for the info. Did you just pop off the bottom plastic fascia (I think I heard it was just a few plastic fasteners) and then reach in with the philips to adjust the aim?mjs1444 wrote:There is a 3/4 to a 1 " hole right under the fog light. Take a phillips bit on an extension, mine is 13 " long. and you should be able to set the bit into the bottom of the fog light. I then backed into my garage , and aimed the fog lights about 6 " under my low beams. then turn to raise the aim
There is a access hole directly under the adjustment screw, no need to remove anything.colonelcasey wrote:Thanks for the info. Did you just pop off the bottom plastic fascia (I think I heard it was just a few plastic fasteners) and then reach in with the philips to adjust the aim?mjs1444 wrote:There is a 3/4 to a 1 " hole right under the fog light. Take a phillips bit on an extension, mine is 13 " long. and you should be able to set the bit into the bottom of the fog light. I then backed into my garage , and aimed the fog lights about 6 " under my low beams. then turn to raise the aim
