2016 Rogue climate control doesn't work
Your stop for everything on Nissan's performance brand. Whether you're looking for info on the new Sentra NISMO concept, the GT-R NISMO, 370Z NISMO, or just some of the many NISMO branded parts - You're in the right place.
robertosuarez
Car: 2016 Nissan Rogue SV AWD
The climate control module on my 2016 Nissan Rogue doesn't work. It doesn't even light up. I checked all the fuses (I believe so) but all are OK. Any suggestions? Thanks!
Reason: Revise Title
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The switch panel on a gen2 Rogue just pries loose, no tools required. Take the connector loose and put a test lamp or voltmeter across the Gray and Black wires. If you have voltage then the switch assembly is shot, if you don't then either your HVAC Controller (AC Auto Amp) is bad or there's a wiring issue. You can find wiring diagrams and a complete system description here:
https://www.nicoclub.com/service-manual ... %2FHAC.pdf
robertosuarez
All of a sudden the climate control module started working, then, after a few minutes it stopped working again.
Return to “NISMO”
