mashpotatos »
https://forums.nicoclub.com/mashpotatos-u314878.html
Sun Jan 12, 2025 11:24 am
2016 Pathfinder
This is my firends car that was brought to me.
What was done:
They first took the pathfinder to nissan for regular serivce. A few days later cyl 3 was not working and car was runningn rough,. They took it back to nissan and they could not fix the problem.
They then took it to an outside shop and they replaced the coils, spark plugs and still cyl 3 is not working.
They then brought it to me and tested coil connection on cyl 3 and found it had a 12v going to it, but it was not getting the low voltage current/pulse for making coil spark. Other coils, had 12v and the low voltage. Did a wire trace to check for a broken wire, but the that was okay.
So I suggested they replace the ecu with a used doner. They had nissin do the reprogram on the doner ecu, but it still had cyl 3 not working. So, I rechecked all coil/sensor/pulgs connections. Then when starting it up, cyl 3 was sill not working. Car then died and now it could not start. So now when testing the other coils, all are not getting the low voltage pulse. So I installed the old/original ecu and still not starting.
So I checked fuses and they look okay, did a diag and found a whole bunch of erros, engine, bcu, airbags and more.
So right now, it seems one of the modules is causing this problem.
Any suggestions???
