2016 Nissan Rogue Projector Retrofit
rajesh1136
Hi Everyone,
I have 2016 Rogue SV with halogen lights and want to retro fit projector. After a long though and discussing my options with various folks decided to get Morimoto h1.
Any one did Retrofit ?
Also, is there a video on how to remove the headlights. This will be a DIY and just worried to remove bumper to get to the lights.
Also, should i get a new pair for my retrofit just in case ?
datechboss101
Car: 2016 Nissan Rogue SL -- RIP
2018 Nissan Kicks SR -- RIP
2019 Nissan Rogue SV w/ Prem. Pack
To remove the headlight housings, I am pretty sure that you have to remove lots of things (cause Nissan doesn't like to keep things simple). Also, where are you located? This is because there might be some shops in your area that specializes in retrofitting headlights and taillights. For me, I know few Soccer dads (Yes, VanKulture is a thing) and they had their lights retrofitted. One had his done in Japan, while the other before moving to PA had his done in Tampa. There is also one shop in New York called KM Retrofits, that posted a video of a 2017 Rogue that they retrofitted. However, in mine, I just upgraded the crappy Halogens to LEDs made by Precision LED, and it did wonders, and I am still using the stock housing.
Here is the video:
https://youtu.be/nTQ7s7IY7aw (Part 1)
https://youtu.be/ttOrM3z0NXg (Part 2)
Return to “Rogue Forum”
