2016 NISSAN ROGUE DRIVER WINDOW DOESN'T WORK
robertosuarez
Car: 2016 Nissan Rogue SV AWD
MY 2016 NISSAN ROGUE DRIVER WINDOW DOESN'T WORK. REPLACE THE SWITCH, POWER MOTOR, REGULATOR MECHANISM AND CHECKED THE CABLE SYSTEM. EVERYTHING IS OK, BUT STILL DRIVER WINDOW DOESN'T WORK.
OTHER 3 WINDOWS WORK. ANY SUGGESTIONS? THANKS
datechboss101
Car: 2016 Nissan Rogue SL -- RIP
2018 Nissan Kicks SR -- RIP
2019 Nissan Rogue SV w/ Prem. Pack
robertosuarez wrote:
Sun Jun 02, 2019 5:18 pm
BRUH, USE LOWER CASE LETTERS... SEEMS LIKE YOU ARE YELLING WITH ALL THE WORDS IN CAPS!!!!! On to other things, check the fuse.
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
Possible broken wire in harness at the flex point of door hinge. Maybe a relay in there somewhere too.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Spray silicone on the rubber gasket on the other 3 to allow window to open smoothly.
I also do it so there will be less wear on the motor that opens the window.
I try to be proactive before the window motor wears down or breaks.
Moreover, on our Lexus, there is a reset procedure if battery was disconnected to make windows open.
Don’t know if newer rogues does this. Check manual.
If everything works, this is all I can think of.
Return to “Rogue Forum”
